I assume my oil consumption through the PCV is from excessive crank case pressure.
With my compression check and then with oil in the cylinder it showed that the rings most likely the problem.
What is a good and maybe safe way to reseat the rings.
I had luck with the FJ60 using SeaFoam dumped in the cylinder and sitting over night but SeaFoam is very strong and may eat/damage at the bearing.
I was told to add AFT to the cylinder and let it sit for weeks.
AutoRX works in the oil and is a slow way to do it.
I might go that route unless the 89 Supra I put a deposit down on today passes the repurchase inspection, then the 80 will sit as I drive the Supra every day
Any other ideas???
I know "fix in a can" is not always wise but what do I have to loose, the motor is on its way out anyways.
Any other ideas???
