Free floater help Dana 60
What model and years of old trucks had the Dana 60 as their axles? Is there a better option for full float axles?
I want to be able to flat-tow my FJ40 behind our RV and our 97' 80 series. I used to know a Heep guy that had hubs front and rear and he flat-towed his heep for huting behind a camper. He towed that thing everywhere that way with no breakage.
Is their a better way to accomplish this task? I know some on the board have gone with Toyota FF but their list of things to watch for seems long. I want a bulletproof landcruiser that I can flat-tow.
thanks
Aaron
It is my understanding that there was not a Dana 60 rear full float axle that had lock outs on it, that came in any US manufactured vehicle. With that said, I am certain that Hi c or someone else will post up some obscure thing, proving me wrong. :)
You will not be able to remove the axle shafts of a Dana 60, 70, 80, etc. and keep oil in the wheel bearings, which will prove to be a worthless venture.
Warn at one time offered a 30 and 35 spline Dana 60 full float kit for a Dana 60 that has Ford 9" big bolt, big bearing outer bearing mounts, that was apparently available in a semi-float Dana 60 in some early to mid 80's Ford trucks, but, I have not put my hand on one of these either, but they apparently do exist.
Spending 1500-2K on a well manufactured trailer to haul your truck around would be far better money spent, then spending a similar amount on a rear axle so that you could flat tow your truck...
( Custom axle shafts, and spares, new rear brake set up, new rear drive shaft, and spare, new gear set and locker, etc)
But that is just me. I have trailered my junk for years, and would not think of doing it any different. But I have space for trucks, trailers and all sorts of junk...
Good luck!
-Steve
Almost all rear 60's were 30 (if not 19) spline.
I flat towed my cruiser for thousands of miles. Without one issue.
I do have a trailer now tho ;)
thanks a bunch everyone
LOL glad i have made an impression.
factory no, none i can think of at the moment.
Doable yes, I have seen a few that were not warns, i believe they were custom.
custom shafts almost a must, or some longer stockers cut and resplined.
some looking would have to be done, as far as bolt on lock outs, or bolt on driveflanges. Thinking like old dodge style.
I do not believe any factory internal splined hubs of any sort will fit on any rear spindles (D60, d70, 14b)? damn got the parts but no time to play.
buy any D60 rear with big bore spindles.
remember the kits, dont remember how the mount or which parts were in them? What parts are off a semi float 60 ford?
Check the tech section on PBB. The Dana 60 article has a listing of trucks by brand and year for the fronts. I think that would suffice for the rears as well.
