rolliges said:Oh yeah, what's the best way to get the rim of the empty nutsert hole down fairly flush with the rest of the roof???
I used a Dremel.
skyshark186 said:Im not wanting OEM, aftermarket. My question was if the aftermarkets rust the roof like the OEM ones.
e9999 said:the problem with grinding the serts is that they fall in then...
rolliges said:That's right about the nutsert holes. I was hoping for wood boack and hammer approach.
Since I'm planning on covering the foot area with non-slip adhesive pads I'm may just clean, sand, clean, silicone, plug, then patch over.
Never ending saga; hope the weather holds til then.
scottm said:Are these racks worth anything to anyone? I'm planning to remove mine (well it's on my to-do list). From all I've heard here I figure a portable band saw is my least painful option, don't even try the screwdriver. My biggest concern there would be if any screws or inserts turn while the blade is trying to cut them. A Sawzall might work, but might rattle the nutserts right out of the roof.
e9999 said:no the problem is that the "OEM" (really port) rack was put on by drilling holes in the roof and putting in flimsy nutserts. The screws get rusty, the serts get rusty, and the roof metal gets rusty.
If you put in an aftermarket rack on the gutters, it's a different thing altogether, so no worry.
JDay said:My factory roof rack came off quite easily on my 96. Lucky I guess. Unfortunately, I broke one of the foot mounts where it ties into the rail when I dropped it on the floor. Does anyone have the foot mount portion they want to get rid of?
OZCAL said:Do you mean the pads you put on the floor of a shower?
