Frame upgrade help
I'm looking for a Houston Tx area shop that can upgrade my '73 FJ40 frame. The rig is all down to the ground has been blasted and painted and ready to reassemble. I'm just not sure what are the best upgrades to perform.
Brakes?
Steering?
Lift?
Help me guys I want get this bad boy rolling.
i would think about doing a disc brake conversion and a power steering conversion if you looking to do some mods right away
Claude Balls.....Welcome:flipoff2:
Sincerely,
Seymore Kuntz:D
Claude-A whole lot depends on how deep your wallet is. The very first thing I would do while it is apart is to install power steering. The Saginaw conversion is quite nice-inexpensive, powerful and well worked out in the Cruiser world.
The second thing I would do is lift the truck, but you have a key decision to make. Do you want to stay spring under, or go spring over? There are pros and cons of both approaches. If you don't know what it means, then stay spring under.
Brake work is not frame related, but now would be a good time to swap in the knuckle-out parts from an FJ60 (my favorite) or a mintruck. That will get you disc brakes up front for not too much $$. In my opinion, well adjusted drums work fine in the rear and rear disc brakes can wait.
These three things will get you started-they are great on a stock street driven truck and nearly essentail if you want to off-road it. What do you plan to do with the truck? If you give us your intended use, and your budget we can help you more.
Good luck with your project-remember, power steering first.
Thanks Cruiserdrew, I won't say the pockets are deep but rebuilding my FJ 40 is budgeted. I want this rig to be a good and dependable head turner when I'm mobilin' down the road. And if the need arises ( generally alcohol induced ) I want to be able to pull off the road and go where the lonely go.
My problem is time I want to hire someone to put this ride back together and I was hoping to find someone in Texas perferably Houston to rebuild it.
But thanks for the tips.
Welcome.
Well if your pockets are not deep, you had better hope you find someone that is very sympathetic to your cause, because getting a box of Legos for a truck and having someone put it together is not going to be an inexpensive venture to say the least, let alone upgrades.
Good luck!
-Steve
Steve is right, I hope you have a place to work on it. It takes time, patience, and money. If you pay someone to do it it's going to take time, patience, and alot more money. Trust me it takes time, when you need a part you just don't go down to the shop and pick one up on a Saturday and walk out with it. While most parts are fairly easy to find (espeacially if you navigate this site) they are not always right next door, the UPS guy will come to know you on a first name basis. Congrads on owning the worlds finest fourwheel drive, this is where the whole addiction started for me.
