Frame swap question?
Hey guys! I am a Jeep convert and have a '71 fj40 that I am in the process of trying to restore. My frame was bent, in the front, in an accident and I have aquired a '73 model fj that I am going to try to use the frame from. Because of the difference in the '71 tub I am going to try to swap axles and steering components from the '71 to the '73 frame. My main question is will the steering box and components swap over to the '73 frame without any modifications? Just wanted to check with the pros since I am new to the FJ community. :confused:
Thanks,
Kevin
I think it will, but I do know that the frame mounts for the '71 are the same all the way up to '78. I swapped a '71 tub onto my '78 frame with knwo problems. I am sure someone has done it before and can tell you. Good luck!!!
Take lots of pictures!
later
Ryan
I dont' know of any frame differences between '71 and '73.
The tube behind the transfer case changed in 73 for the four speed, but that will just make it easier to install a longer transmission. The steering box should just bolt to the frame with out any problems. In 79 is when things really changed with the frame.
John
Thanks for the info
Thanks for the tips! I can't believe the difference between this FJ and the Jeeps I have had. Everything is much beefier on the Toyota!
I saw the crossmember difference between the 71 & 73 but that is all I could see different. So I am going into this hoping everything matches up ok.
The only other item of concern I have is that I would like to put disc brakes on the front. I hate the way drums pull if they get wet. Any suggestions for kits?
I'll post some pics as I make progress :)
Thanks again,
Kevin
FYI
When I swapped frames on my 78, I removed the rivets on the steering box bracket and then bolted it back on. This was in anticipation of the mini power steering conversion, which I did about a year later. It made the install much easier.
Disc Front Kit
SOR (Specter Off-Road) sells Front Disc Kits. Its from the knuckles out. I think the part number is 084-100A-U. If you don't care for the price you could always find your own. Hope this helps!
Thanks for the info
Thanks again,
Kevin
I swapped my bent 74 frame for a straight 72 frame and the only difference I had was the steering box mount, I had to drill and tap holes for the brake line brackets on the passenger side, had to cut out the tube cross member and weld in the one from the 74, and the rear cross member I had to swap out.
Kevin
