Frame Question
So Cal Mountains
I took off my stock front bumper for the first time today so I could work on attaching brackets to mount my snow plow. Looking in the open front end of the of the box frame, I can see two separate pieces of sheet metal with large holes in the middle. One in the front has a smaller hole, and the one behind, a larger hole. The pieces look like they are welded to the sides. Does anyone know if these are reinforcements to help keep the tube from crushing, or are they for mounting something?
Removing the one in front of each side would make it easier for me to access the nuts that I need to put in there to mount my plow bracket, but I don't want to weaken anything, especially since I'm going to be putting a load on it.
Can't help you on your question, but I am wondering what plow setup are you going to use? Been thinking about putting a plow on mine too.
Hey Jeremy, looks like you may be from my neck of the woods.
I've got a Snowbear snow plow I purchased used. The PO had it on a Heep. Snowbear makes mounts for most trucks, but not for LC's. I used to use it on a Nissan Xterra and a Nissan pathfinder for about 3 years now, and the plow has worked reasonably well. It doesn't have hydraulics so it cannot apply downward pressure other than it's own weight. (It's steel so it must weigh close to two hundred pounds.)
I bought a universal mount that requires some fabrication and that's where I find my current problem.
Can anyone tell me what holes are used for aftermarket bumper mounting, ARB, Slee, Etc. (Just the stock bumper mount holes or the heavier duty tow point bolt holes or?) Do the bumpers with winch mounts attach to the front cross member for support or is that front cross member not strong enough to offer much support for front to back loads?
Maybe someone who has fabricated a heavy duty winch mount has an idea of something that will work. :hhmm:
Thanks in advance for your help.
PS Jeremy, feel free to PM if you want more details on the plow. I just didn't want to bore everyone.
Use as many frame holes as you can, and do not cut off anything if you can avoid it! A plow or even an ARB bumper puts added stress on the frame.
A snow shovel often ends up pushing up frozen soil or asphalt as well as hardened snow. This puts extreme pressure on the military fence builer. You need to consider the front frame as a support for a bulldozer. When you are pushing ice and snow, you are using the truck as a bulldozer. That takes a lot of pressure!! Do not weaken the frame. Instead, use it to stiffen your position.
Do not remove any steel from the front frame. Instead, use every bit of strength that is available and add some if you can.
