Frame Ground? Which starter?
Spokane
Okay this should be pretty simple for use guys.
1981 2F
First wheres a good frame ground for my battery, block and starter? Should I just bolt the ground anywhere close to the battery?
Second how do I know what kind of starter I have (old starter or Gear Reduction.)
I have three starters and they all look the same. I have one wire going from the solenoid to the battery and one small wire going from the solenoid to?
I would post a pic but it didn't work last time I tried.
In this cluster fk of a pic, you can see a NON gear-reducted starter motor.(hopefully)
I ran a ground lead from the negtive post on the battery to the engine, and then one from that same point on the engine to the frame.
Good luck!
-Steve
There should be a stud terminal on the solenoid, on top of the starter motor, that attaches to the positive side of the battery.
There should be a spade terminal to the right, IIRC, of the stud terminal on the solenoid, this is where the signal wire from the ignition switch attaches, to acctuate the solenoid when the key is in the 'start' position. Sorry, I cannot remember the color of the factory wire that attaches there....Black with a yellow stripe I think...
There is a short lead from the other side of the solenoid that I do not use...
Hope this helps.
Good luck!
-Steve
Okay that was really helpfull poser! After seeing that pic it looks like I have three older starters. The only thing I need to hook up now is the ground from the block to the frame.
(BTW these questions are stemming from slow starting issues.)
The top motor mount bolt makes a convenient battery ground to engine. Make everything clean and shiny.
A heavy grounding strap from one of the bellhousing or starter bolts to frame will help keep lights working. Make it long enough to allow for engine movement. Clean, shiny.
Battery to starter post. battery ground to head and frame, I used the hanger on the front used for engine hoist and a battery tray bolt. and grounded the block to the frame under the air filter.
On my Toyota starter the excite wire to crank the starter was on the passenger side. spade terminal, On a USA cheapo I had it was clsest to the block. So you may double check that.
this is a GR starter. BTW this is a 82+ starter mounted on my 64 F motor.
on a late 40 at least the battery ground is on the frame, just by the PS shock, you will see a treaded hole on the frame around there.
Thanks for the pic pimp. I now know I have three old starters. :(
I'm going to get all the wiring straightened out and I will let you know how it turns.
I think it's a grounding issue.
when these three starters give up I will move up to th GR starter. I have enough cores.
