Frame dimensions missing from FSM
Arizona
I was looking at the frame dimensions for a project and noticed that there are some dimensions missing from the FSM and most of them are the dimensions for the suspension. Does anyone have a drawing of all dims? :hhmm:
I was looking to get this into CAD and as soon as I looked at it I seen there were some major missing pieces. I could measure but was looking for the easy button, it is hot in my garage :grinpimp:
I was gonna post the pics i had and then realized they aren't there!
But these could be imported into a cad program, scaled to the dimensions that are there. Then use the drawing to measure the other points.
I have done this with solidworks. What cad program are you using?
Most body shops with a frame rack could get it for you in a second I'm sure. You may want to drop by one and see.
I've been working on a frame model. I just took some pics from the FSM, scaled them, and made the model. Still need to add the suspension/body mounts and crossmembers, but the rails are there. Model will need to be tweaked with hard measurements off of a real frame for better accuracy, but this route gives a good starting point.
Pics:
That looks nice. What program are you using?
Apparently I'm not the only one... anybody ever get anywhere with the missing dimensions? I started doing 80 vs 60/62... I don't have either frame to take measurements from.
