I don't think that would work very well with the porat axle in the front.Rich said:I'd look into the rear steer that chevy offered on some of their pickup truck models not so long ago. Rear steer would go a long way to negate some of the drawbacks of dealing with a long wheelbase threading in between tight obstacles.
fzj80kidpen said:Look forward to see this attempted even if you do not succeed there will be much learned.
Correct. The chevy rear steering is electronically controlled. At low speeds rear axle steers opposite from front, to greatly reduce turning radius. At high speeds, turns same direction, enabling lane change manuvers at higher speeds with greater stability. May give some insight on what could be adapted to a volvo axle.Walking Eagle said:I think he ment from a how to steer standpoint....
The chevy rear steer axle is a Dana 60 steering axle. Hardly a POS.Walking Eagle said:...not from use a POS Chevy steering rear axle.
SOCALFJ said:Didn't you just swap the portals in? Now your already wanting to swap out the rear?
