FOUND - Stolen LX-450 - Calgary
Awesome - you beat some really tall odds getting it back essentially unmolested (+1 buy that farmer a case of his favorite brew!!)
Getting a quality installed, properly set Viper/Clifford will take you a long way.
Here's the 2nd to top model (I run, flagship just adds a color display remote :meh:)
VIPER 5706V 2 WAY CAR ALARM REMOTE START KEYLESS SYSTEM LCD PAGER 5704 DEI | eBay
Unless you've got ~dozen alarm installs to your name, I highly recommend getting it done professionally. I can get the DEI installer notes for our rigs, but nothing like a quality install done with quality terminals (real T-taps, no Scotchlocks, etc.)
The flagship & the 2nd to top (one I run personally) - have a 2 way remote that chirps & vibes if the alarm is tripped, also can be configured to notify you if the 'pre-warn' goes off. And it logs if it was tripped while you were away from your remote.
My version has a 1 mile range for the feature, and the antenna & blinking light mount real obviously behind your rearview mirror on the windshield - so you see a very bright blue light from 20' away.
We've done the whole starter kill convo (not a fan of wiring it myself, but a starter kill is the least of a thief's problems if caught snooping).
The kill switch is also an item that if done right negates any need to wire the starter kill from the alarm. I've got a lot of ideas there, PM me if you like - we have too many vistor/'guests' on the forum so I rather talk specifics less publicly.
I may finally make a piece that allows for multiple options, but I have been trying to get A pillar guage pods going for awhile & between that & my mods I make on my boat I get too distracted / spread thin.
GLAD YOU GOT IT BACK!!!!!!!!!!!!!!!!!!!
Killing the fuel pump is the easiest to do you just intercept the relay and make sure you install the switch away from the dash or center glove box . Pm me if you want to know where the best place in install switch. Rather not tell the world by way of the forum. Long ago I use to have a electric line lock on my trucks front brakes, They bleed off pressure when the sit but the first time they hit the brakes that's where their gonna sit,normally in a driveway or at the stop light.
Honestly, if I'm somewhere shady I just pull the efi and blinker relay. Unless the thief is rolling with a bunch of toyota relays good luck. Not the ideal solution but pretty painless and I don't think most things will look for this. Also, unless u know what the symptoms are the car is just going to crank and crank.
This is the very reason Land Cruiser owners should have a hidden kill switch on their rig. After reading this story I'm now going to get off my ass and finely install one on my truck.
Ditto
But if they find your spare key and you have an alarm, can't they disable it anyway?
