Found part of a 2F
Orlando, Fl
i found almost all of a longblock 1983 2f. all it needs are the head, intake, and exhaust manifolds. and a 4 speed tranny. 2f is $300 and 4 speed is $250.
what do you think? how hard would it be to find the head for that engine?
Jonathan//SandRider
Heads, from Spector Off-Road, are only about $500 with no core needed. These are complete heads excluding the rockers.
What is the status of the engine? It would be hard to do a compression check on it with out a head. If you know it's good engine and if the owner comes down in price it could be a good buy. I can hook you up with a rebuilt 82 head. I also have several fj60 trannies/tcase, intake/exhaust in storage. I'm about 4 hours from you. Personally I would try locating a complete engine.
im not sure if the the 4 speed is an 83, but it is out of a 60. but, the 4 speed also has the xfer case connected to it and will be sold together.
the plans for the engine is to be rebuilt, ported, polished, run slightly higher compression, run either a 2bbl weber or aisan carb. and, will hopefully be dropped into my 68 fj40
