found it
HandForged
Built Not Bought!
Montana
Give me some enlightenment here. Has anyone converted the in tank pump for diesel? I am about to embark on such a thing and I am sure someone has already been there and done it so....
why? The injection pump pulls the fuel to the injectors.
I guess I thought that would be obvious, maybe not for some. I am converting to diesel, therefore I will need a fuel pump in the fuel tank that will pump diesel. I am building a LARGE engine that will need more than the injection pump will supply...
I can install an inline pump, gut out the factory pump and replace it with a draw straw but it would be a good bit easier to have the in tank pump.
Found it, part number I was looking for is 11102713 application is 3.0l diesel
Most diesels utilise the injection pump to draw fuel from the tank to the pump. Toyota HDT, HZ etc don't have an in tank pump
If you add a pusher pump, you needed to be careful of pump pressure. An increase in pressure to the injection pump can increase pump case pressure and alter infection timing with some diesels.
You are correct, if I were using a Toyota diesel for the swap it would be a concern. I'm using a 1.9L VW with a custom built mechanical landrover pump. It will need the extra fuel pressure. The pump I was looking for is a low pressure pump, that is the reason for asking the question. I'm very well versed guys, I'm a Master Diesel tech. I was just looking for the part number for the pump I had in mind. It is standard on the Brit diesel cruisers. I think it's a 3.0l
More info always helps us help you. That last post coulda been your first. Way outta my wheel house so sorry, I’m no help here. Sounds like a cool project, keep us posted. There are a couple 1.9 swaps in the 40tech section that may shed some light.
A 1.9 for such a tank? I would do something else if swaping as I want the real benefits of diesel....that is low end torque...with my 1hd-t torque comes in fully at 1400 rpm and hp much later...with any 4 bangger engine, revs must be higher up...for me there is no comparison as to just let go of the brake and climb an obstacle without even touching the gas pedal...now if you are looking for speed, well, that is just a different thing all together...
The 1.9 VW diesel I am swapping first of all isn't going into a full size FJ80, just on a 80 frame with the 80 fuel tank, hence the question. It will have a fj40 body. Secondly it makes more horsepower than a stock 12v cummins at 220 nominal where it is now.
