Long story short, I missed the step of placing the crank shaft at 45 degrees CCW of TDC when removing the cams for the camshaft seal replacement. I am afraid that I bent the valves since the notice in the screenshot says the piston head comes into contact with the valve.
Codes I have are P0300, P0301, P0304, P0306, P0308, and P0051.
Did compression test on cylinder 1 and came as 0, and I immediately realized I may have screwed the valves.
My question is, are there any resources y'all have used or anything I should know when removing the cylinder heads and replacing the bent valves?
