Fogging Up
My FJ40 fogs up badly on the side windows and especially on the hardtop windows when it's raining. It reached the point where I had to carry a squeegee in the cab. The defroster will clear the windshield after a bit, but the moisture gets in and my guess is it just simply has no way to vent out.
Has anyone else run into this problem, and what was your solution?
I thought about the SOR windows for the hardtop sides, the ones with the sliders. But they might allow in more water than they let moisture out. (Still nice for circulating air, though.)
Whatever the solution is, it has to be waterproof itself due to our rainy season (only rains once a year here... September through June) and we do get some monsoon quality rains. It also needs to be unobtrusive and not spoil the looks of the cruiser.
make sure your Fresh Air vent is pulled out. If not, you are recirculating the same air over and over and the moisture builds up on the windows. Works for our 60 and the 40.
hth, Don
Ah, the fresh air vent also feeds the heater? I put a magnetic sign over it because it leaked into the cab so bad when it rains. I thought the heater was independant of it.
Put a magnetic sign over it? Are you talking about the cowl vent infront of the windshield? The heater has it's own vent over by the passengers feet. It should have a knob with a "V" on it next to the heater switch. If your cowl vent leaks you may need to replace the drain hoses.
Try some of that Rain X anti fog stuff like people put on the inside of their ski goggles. They make it for vehicles. I think they sell it at GI Joe's.
Yes, the cowl vent. I cut a thin magnetic sign to fit over it and painted it blue to match. Yes, I know the drain hoses need to be replaced, but I haven't figured out yet how to take the assembly apart. I've seen the exploded view, but that's not exactly helpful for instruction purposes. I probably should have asked here, but forgot about it, since it's summer.
X2:)
There is a knack to applying it so it does not streak and it needs to be replaced every so often...but it works.
Ed
