FnEGR Block off plate material?
WI
I wanted my title to say FN' PO's and EGR blockoff plate material and removal?
In my quest to get rid of my check engine light for the EGR Valve, I did the "redneck EGR Fix" as shown in this thread.
https://forum.ih8mud.com/80-series-tech/332126-94-code-71-egr-bypass-redneck-technique.html
It worked great for about 1 week. The truck ran and drove excellent. No more check engine light ect. Then the light popped back on. Naturally I figured it was the egr valve again being the culprit....
To my suprise it was a #6 cylinder misfire which I have never got before.... It got me to thinking, if I tricked the computer into thinking the EGR valve was not there and not operating, why the hell have the components there and also could there be some sort of leak from the intake to the #6 cylinder even though the EGR is supposedly disabled.....
So, I began last nite to remove the EGR crap. Also I checked my spark plugs and wanted to see what was going on in cylinder #6, and again to find another great suprise, the PO decided to put Autolite spark plugs in.. What a joke, I wouldn't even run those in my lawn mower.
I am actually shocked I put about 8000 miles on this rig with these plugs in it. The plugs were not even tight, I removed all of them with a simple twist of my hand on the socket extension.
Anyways on to my question, can I make my blockoff plates out of stainless steel?
Stainless steel when heated tends to hold the heat, longer than mild steel or aluminum.
the intake one is a no brainer, but the bottom plate being close to whatever is going on inside there, is the heat going to affect my stainless blockoff plate?
I am figuring it isn't, but I figured I would ask...
The redneck technique does not work on OBD-II trucks. You need to use a resistor.
No reason you have to go with stainless, I would use regular mild steel myself and paint with a paint capable of handling head (header paint, fireplace paint, etc).
I highly doubt the misfire is from the EGR system. Far more likely the cheap sparkplugs that are poorly installed. Also check your wiring to make sure it's in spec.
On mine it worked for a week or so with no resistor.... I thought there was a thread that it did work without the resistor on OBDII... Anyways, if I need one, I will get one down the line....
The truck has had EGR issues since I bought it, I did swap out egr parts and the vsv whatever it is part, and still had issues....
My harness that was partially melted away... This was my reasoning to get rid of the EGR and the fact I'd rather remove the EGR, than replace the headgasket down the road, but that's a horse that has been beat to death already in other posts....
If I use stainless, I don't have to paint it then... ;)
I have no doubt the missfire was from the piss poor spark plugs/wires and install of them from the PO. Just odd, that I got a #6 misfire, when I have never got that code before, it was always the EGR malfunction/failure.
I figure, replaced the plugs/wires, and remove the EGR crap and I should be golden.... :beer:
The system is not picky. You can run as low as a 1k resistor without issue. I would personally go with about a 4.7k as being "better", but if it's not availible run something else. :meh:
The fact that you ran with no resistor for a week (in cold weather!) shows how not picky the system is.
