Flywheel
It is not something that I would label as being commonly replaced. They should be resurfaced when you change out the clutch disc and pressure plate.
Why do you think that yours needs to be replaced?
Is it cracked?
Well i just replaced the starter in it because it was draggin alot when i started it and it had a corroded wire comeing out of it. Also it mad a bad grinding sound right before it started(the sound a car makes when the cars already started and you turn your ignition) and it still makes that sound and drags. I was starting it and someguy told me that it needed a new one.
CHECK YOUR GROUNDS! a bad ground on the starter can cause all these symtoms and will destroy a starter very quickly.
i think the ring gear can be removed and replaced by a machine shop... but it may be easier to buy a used flywheel and swap it.
hth. carl
