Flushing everything at 146k miles
Saratoga Lake, NY
Got around 146k miles, have lockers, 2 year old HG.
Found a pretty good amount of sludge ( 5-6 t spoonfuls) in the radiator reservoir today. I'm running the green stuff in the rad. and haven't changed the fluid for 2-3 years.
Making a list. need advice on-
First- flush with distilled water? How much distilled water do I bring to the shop that will be doing the flush?
The green antifreeze is prestone, correct? Do I get the 50/50 mix?
Flushing the transmission using- dextron II have on hand up to 20 qts.
FT,RR, and transfer case, all use hypoid gear oil API GL5? Any special oil?
bleed brake fluid- using dot 3?
bleed power steering fluid--
Thanks for any input!
