Floorboard is getting hot
Austin
Website
www.cruiseryard.com
While driving my 40, I notice after about 20 minutes of driving that the floorboard and area under and in front of my seat are really warm, almost to the point that it is uncomfortable. Does this happen to anyone else? If not, any ideas on what this may be?
i got these symptoms when my tranny had low oil in it on a long trip... apart from that no fing idea
Yeah, the floor under the drivers seat gets pretty warm. Then again the exhaust pipe runs RIGHT UNDER the drivers floor, and there is no heat shielding....
do you still have the cat? if so do you still have the cat heat shield? my 82 with the cat and stock heat shield doesnt get hot at all.
The engine is stock 2f. The exhaust is new, but I do not know if it is OEM. I purchased the cruiser shortly after it was replaced from the PO. I doubt it would be a toyota muffler, but will check.
Also will check to see if the heat shield is still there. And will check the tranny oil level.
I do notice that where there is a lot of heat, there is a black coloring. Not sure if it related to the cause or not, but will have to examine further. I would take pics, but my camera is in the shop until next week.
thanks for the help
reflectix and some black rubber sheets to lie down will help a ton.. I've seen 40's get so hot in my neck of the woods shoes will start to melt.. Course we're talking over 100 degrees outside anyway!
The cat convertor sits right under the driver's feet - there's a heat shield above that that reduces the heat into the floorboards. It still gets warm, but not too warm.
If the heat shield is missing, or if the cat convertor is running too hot, you will get exactly the problems you describe.
Normal operation for the cat is 300-500 F, IIRC, and they can get over 1000 F if there is a problem.
The cat convertor runs too hot if you are running too rich, and will eventually be destroyed by this.
Don't neglect this, as the repairs can be expensive.
I have an 1982 FJ40, bone stock, and the cat is still fine at 143K, with no signs of burning up, so they can last.
Kirk
