floor tie downs in cargo area?
e9999
Gotta get out there...
Moderator
US
well, I never have enough tie downs in the rear for all my boxes of junk. And I even use the middle seat boltdown holes with custom hooks. So I'm thinking I'll put several tie down rails to make that easier.
Now, a cursory glance at the existing seat brackets and (pitiful) corner tie downs suggest these things are just basically a hole and welded nut behind the sheet metal, maybe with a reinforcing plate (I forgot).
So waddya think? I could just bolt something to the floor anywhere with a small backing plate as insurance and that would be enough to hold heavy tool boxes in a rollover or would that be sheared off the floor right away? Of course, the existing tiedowns are just that anyway IIRC so can't be much worse... (unless they are located close to cross members as I seem to remember)
what about all of ya drawer guys? are you confident they'll stay put?
The 8 bolts in the floor that hold the 3rd row seat "legs" are designed to hold the force of the passengers and their seatbelts during a sudden (unexpected) deceleration, so I would be comfortable using them as part of your system. It sounds like you have a variety of stuff/shapes to tie down, so maybe a set of adjustable tie down rails might work. You could also attach a sheet of thick (3/4") plywood to the cargo area floor using those 8 bolts and then attach other tie downs where you need them (with good sized bolts and washers).
thread gone to sleep, apparently
so everybody thinks it's just fine to just bolt down tiedowns to the floor sheet metal?
No, IMHO, I would use existing mount locations (seat & bracket) where possible. If you need more, use backing plates under floor sheet metal. While holding heavy objects, floor may become bent out of shape in a rollover, but not as much as the exterior body sheet metal. Depending on the cargo weight, of course, the floor dis figuration would be the least of your problems.
not concerned about floor distortions in a rollover, of course, more like the tiedown and backing plate would just shear right through the sheet metal. But probably not likely with limited weight cargo.
Yeah, probably be a good idea if new tie downs are added to at least match size of backing plates for for existing mounts. Going larger would just increase your safety factor. Stay as close as you can to existing floor supports and try to avoid adding a tiedown in the middle of unsupported sheet metal. I don't see a problem if you use that method.
