I have been searching everywhere for info on this so I have to post
I am considering going to a floor shifter for a 350/th350 conversion in my 72 40
Does anyone have experience with this?
Or can someone tell me the best way to get the right gm steering column (flaming river?) but with column shifting? and the correct linkage?
any help is appreciated as always.
A tranny hump mod is in your future. Hopefully, it will stay where you put it, so if that is out of the way, it should stay out of the way
Look good? s***, it's a Lokar
I had this shifter in my fj40. I was running a V8 and TH/400. The nice thing is that you can hook up a reverse light if you need it. It is a well machined and has a great stick height.
The down side is that it does not bolt on to the transmission as securely as I wanted. If someone drives your truck and they don't know to push in the center button they can knock it its mounting bracket. Not a problem if you are the only driver. This can also occur if you lean against the shifter as you are working on the truck.
Not a real big deal and it easy to fix, but it does get annoying at times. It is certainly better than anything else I found and comes with great directions. Took me and hour to install (I was replacing a Hurst shifter that was terrible).
I used a column from a 1989 GMC Jimmy (Chevy S-10 clone). It has the column mechanism intact. Don't know about the linkage since I still have the floorshift 3 speed at the moment. Hopefully, a 700R4 is in my future, then I will know more about the linkage. I do not think it will be very hard to mod stock linkage to work though.
By the way, the column also has tilt, ignition, wipers, and headlight dimmer on it.
