Floor pan RUSTED!
The West
well i was up at ron's shop in gilroy again and decided to poke my drivers side floorboard and ended up finding that i could poke holes so easily all over my side of the cruiser. so i poked some more everywhere on it and it seams the only problem lies within the drivers side floor panel.
well. im kinda in a rush to find out what place sells the best floor panels that curve to fit the tranny hump and everythign so the shop doesn't have to put to much labor into making it fit.
ccot and canada cruisers have them but they don't curve to the tranny hump
and advise would be more than appreciated as i have to let him know by tomorrow when i can get the panel to him.
thanx, Rachel
Try this mud supporter
http://www.ih8mud.com/ads.php#banners
thanx but that doesn't even have my floor pan.
im looking for advise from people who have gone with a certain company and have been really happy with it. Something that basically fits right in to the bumps in the tranny hump.
Er..emmm..you're gonna have to tell us what year your truck is.......
I had to fabricate my 73 pan, there really wasn't a reasonably priced one available for it that I wanted to use, so I spent the time to do it, the PO had put a bondo patch on and made a small problem a large one. I sympathize with you it took a great deal of time to fab the parts, Larry
sorry it is the right drivers side floor section for a 1970 fj40
awsome! are they pretty thick and durrable?
how long did it take for you to install this?
what guage steel are they?
and im sure they would work with the lock box that fits under the seats on my 70. I like canadian cruisers but I have noticed their panel strip indents are thinner than stock. It looks funny.
They were as thick as the original. I had the tub off so it was easy to flip it over and drill out the spot welds on the old floor and cut the floor out with a cutting wheel. The hard part was remouting the front cab mounts in the right place. (I swapped out my cowl at the same time)
The floor is pretty close to the original sheetmetal. It runs out to the outer rocker panel and up to where the floor board angle up.
The ridges in the floor are almost perfect.. If you look you can see that they are about a 1/4" closer to the rear than the stock but they are the same width.
I drilled the holes and welded in the nuts so the seat hardware would mount the same
Kevin
wow. ok looks like i might go with their product then. thanx alot for answering my Qs.
any other advice i should keep in mind?
The CCOT panels have holes where it hits the box channel in the back and where it hits the rocker panel so it's easy to spot weld back in. Get some seam sealant to caulk the seams around the floor when your done to keep water out of your rocker panel. I cleaned out my rocker while I had it open and painted it with Por15 before I welded the new floor in.
Kevin
k thanx. ive got a small tub of rustbullit. i might use that. Ron Diaz is going to do it as i have absolutely no bakground in welding so i will ask him what he plans on doing for that . SO you really have to paint the places where your going to weld before welding. I thought they closed tight and absolutely would not corrode?
do you think rustbullet is a good solution?
Well you should use a weld through primer but I brushed both sides of the spot weld seams with Por15 to seal them after I welded them in (I painted the whole bottom of the tub and the floor board area with Por15 and then painted over it with the Freeborn red)
From what I've read Rust Bullet is as good as Por15 and easier to use.
Kevin
ok cool. but i didn't know you needed to paint it before welding. If i didn't paint it before welding , but painted it after it what would happen?
ya i baught some rustbullet a while ago and never used it so i thought , hey sense i have it lying around why not use it.
ok i will .thanx so much for all that. really appreciate it!
Rachel
Toyo FJ40 said:
As long as the seam was rust free before you weld and you seal the seam with the rust bullet after you should be fine.
You should check under your gas tank while your working on it.
Kevin
You may want some kind of drainage built in. It could be exposed to condensation which would cause rust. This has happened on my FJ55.
I've seen a ton of this used on british restorations.
Waxoyl..its a chemical solution that prevents corrosion etc.
