Just wondering if anyone else has run into this or may have some input.
1990 HDJ81. Driving into work this am all the warning lights on the dash which light up when you first turn the ignition on (i.e. a/t overheat, batt light, both turbo lights) were flickering on and off. Truck is running great just seems like a short or bad connection somewhere.
This has happened before when I would sometimes run the offroad lamps, they draw about 35amps so I replaced the two batts, seemed to clear it up but then again this am.
Checked out the charging system and it was running fine.
Any thoughts?
Any thoughts?
