Flex = Bind????
Kansastitty
I posted this pic in chat yesterday and I'm not trying to get more airplay out of it, but as I drove it on the ramps to help break in the new springs, the throttle stuck, not wide open, but damn near. I shut it off and it kicked back down. I thought it was stuck on the floormat, but when I started it this morning it did the same thing. I figured the return spring had come off. But...no. Anyway I just let it off the ramps by releasing the parking brake and as soon as it was "un flexed" everything was just fine.
Question is, and I'm NOT an experienced wheeler, is this normal or are my bodymounts in need of replacement? NBD since I will probably never find myself in a real world situation like this. I have rod linkage and it seemed to be binding where the horizontal rod goes through the firewall.
Ed
Sounds like it is binding up to me Ed....
You should be able to put the truck back in that position with a jack, and check the free play of the throttle linkage with the truck not running...
Had this similar situation happen to me while in the rocks once...FUNTIME! :)
Good luck!
-Steve
Thanks, Steve. I could run without the gasket/grommet, but cold/hot feet! I just ought to replace the body mounts, hell, they're over 40 years old. Maybe a little silly kone?
I'm 55 and should be replaced!
Thanks again for the "suspension package".
Ed
this has not happened to me, but i have read on the boards that while flexing like that the body flexes, making your cable bind against (IIRC) the airbox? i can't for the life of me remember who posted it but it wasn't too long ago... they said that it got pinched between 2 parts.
Ed, don't you have a 2F in that there '66 now? :D Maybe it's just punishing you for messin' with it.
The head is back from the machine shop, the block is still there. Parts came in yesterday at Toyota. It's driving time again. Won't swap the motor until next Fall/Winter....God willing.
Ed
Complete hijack :)
Degnol said:
It's driving time again. Ed
You're lucky...
My junk is in pieces.....
New rear axle
New transfer case
New wheelbase
New unforseen expenses
New timeline
*might* have it back together before May.... :rolleyes:
Mods/upgrades....or damage control???
Ed
Steve, thanks for ALL your help!!
Hell, I didn't pop it's cherry, already had a '74 F motor in it when I got it!
Ed
