On our local (RisingSun) forum here in CO Nakman posted this process a few years ago and I finally ordered it and did the passenger side yesterday. Here is the process:
1) Sanded with a little coarser bar on the deeper gashes. Little note here, I should have taken it down a little more on the gashes and the peeling.
2) 600 on all of it
3) Window cleaner off the grime and sanding residue
4) Prime it
5) Painted. Tim pointed out and I noticed it, there is a trick to the "dwell" time to get it glossy and not overspray. I think I did three good coats spaced about 30 minutes apart. I used the same supplier Tim used although they did change hands. You give them your paint code and they will make it. Mine is Moonglow is 1A6. They are now:
http://www.autorefinishsolutions.com
712-262-0047
It's expensive. I think it was about $45 a can. And I did two wheels and I don't think I have enough to another. So you would most likely need two to do all four. I'm going to order another.
It looks quite a bit better but I can still see the outlines of the peeling and gashes. And I would love a sealant. There probably is such a thing but that is where my initiative ended.
Here are the pics. (1) Before. I had some paint peeling (interesting only the flares have had this happen) and some deep gashes (probably from hitting shopping carts at the mall). (2) Primed. (3) Finished. (4) Finished.
2) 600 on all of it
4) Prime it
712-262-0047
