Flare less
Jefferson City TN
if you are running flareless with your 80 did you weld up the holes? Anyone use plastic body tabs/ plugs painted to match? One of mine is cracked pretty bad and I am considering pulling them off and leaving them off. Found lots of good searches/ posts and pics. Just curious if anyone did anything to give them the option to run a set in the future.
As usual feel free to post your fender flaresless pics for enjoyment
I used a heavy foil tape gently applied over the holes so that the depression would not telegraph and then rolled 3 coats of bed armor over them. Pretty happy with how it came out. I would only weld if I was trying to make a show piece. I built mine to use and abuse so it wasn't a requirement to weld.
Got a pic?
Got a pic?
Here are a few from before, during and after. With the wife driving in the last one at a mild section of the rubicon.
What did you cover the holes with Hinterland?
I used a heavy foil tape I found at O'reillys in the body repair section. It was heavier than the hvac foil tape I have for metal ducting so I went for it. Seems to be working well for my needs.
can you give us a brand?
Trim brite. 3"x60". I just cut it into squares larger than the holes and gently put it on being careful not to press where the holes were.
Thanks!!!! Thinking of going flareless and after the nightmare of welding the roof rack holes I am going to go with tape and monsta...
I love the flareless look. I can't look at fender flares the same way anymore. Looks too much like a plush SUV. Besides, I've cut way too much out of my fenders anyway. I'd never be able to keep them. I had the holes welded up and did smoothing myself.
The day I removed them
During bodywork
Now, fenders opened up front & rear
