Flap flap flap
Los Angeles
That is exactly the sound i hear emanating from the bottom, either coming from rear tires or the rear differrential. It only happens between 35 - 45 mph, and goes away as the speed increases. The tires are about 6 mos old, so still fairly new. I had the front bearings replaced based from the expert advice of my mechanic, thinking that was the problem but it was not, the sound was still there. Then, I had it balanced, rotated, and aligned, no luck. It's now getting louder and louder. My mechanic wants to take the rear differential apart, he feels a bearing inside is defective. any thoughts:confused:
No, haven't done the rear wheel bearings. In all honesty, i don't feel it's the bearings. The sound would not go away if it was the bearings, am i right?
Are the tires cupped? what does that mean?
Let me describe the sound again. It occurs around 35 - 45 mph, it's a constant "flap, flap, flap....." like something is lodged in the tires, but there is none, already had all 4 tires checked out. The noise disappears after 50 mph, and comes back if i slow down to below 45 mph.
Its amazing what kind of noises can come from bearings.I went through this with a Celica once.Made the same sound based on your description.Replaced all four tires...still there...4 wheel alignment...still there replaced one front wheel bearing and noise was gone.
Cupping is a type of bad wear pattern usually caused by being out of balance or missalignment or bad wheel bearings.If you look and feel the tread pattern you will feel low and high spots in the wear pattern.Here is some info on it..
http://www.kaltire.com/commercial/medium_truck_tires/cupping.php
Check your tires. I have twice lately had something metal stuck in a tire that made a noise like that. With steel belts you may not get a flat, but a razor blade or screw in the rubber will make a distinct clicking or flapping noise that repeats each rotation. You are more likely to pick up something in a rear tire than a front.
While working part-time for AAA I found that most flats and objects embedded in tires happen on the back. Screws, razor blades, etc. tend to lay flat on the road. They have to be kicked up by one tire to stick in the next tire that comes along. Usually they are kicked up by your front tire to embed themselves in the rear one. Most roadway flats happen on the rear tires. Up to 80% IMHO, but none of this applies off pavement, of course.
With the tough tires that we use (or wish we did) objects in tires are more common than actual flats. Even when your tires are well inflated you should check for embedded items because they may poke thru the steel belts long after they are picked up. If I had left that razor in my tire it would have worked into the liner in time, but all I got was some unplanned tread siping instead, because I heard a noise and pulled the razor out.
Deeper tread, (read: new tires) will pick up debris much more than worn ones will. An old tire with worn tread will slide off of a nail while deep tread will guide it in to poke thru the core of the tire. Hence the myth that every set of new tires seems to result in a flat. It is all random violence of road debris under your truck while you drive. The rear tire is more likely to catch it, and a new tire gets it more often than a worn one will.
95eighty,
Thanks for the info. the tires are too new to determine if cupping is prevalent.
Brian Macgyver,
Thanks also for the info. Had the tires checked out again, and rotated, still no luck. Looks like i have to take apart the rear wheels.
95eighty,
Brian Macgyver,
If you rotated the tires and the sound is coming from the same place chances are you can rule out the tires being the problem.My money is on the wheel bearings.
I see you are in LA.Have you checked out the SoCal 80's board?
https://forum.ih8mud.com/forumdisplay.php?f=91
Check it out.If you continue to have trouble with I would be happy to meet up with you and take a listen.:cheers:
95eighty,
Had no idea there was a so cal board. I would gladly meet up with you, and get some expert advice. Hopefully you can recommend a shop or mechanic. Mine wants to rebuild the rear axle. I feel he's guessing. Thanks.
