flange changingquestion
i want to put a fj60 front cv driveshaft in my 71 fj40. from what ive been told i will need to change my transfer case and axle flanges to 4speed flanges to fit the driveshaft for the larger bolt pattern. i just not sure if the splines are the same and if this is possible. if i cant get flanges to fit from a later cruiser what are my other otpions to make this driveshaft fit. i thought iv seen adapters around...
Randy's Ring and Pinion has flanges for the thirds that are drilled for both patterns . Just let them know what spline you want. Keep hunting for the t-case ends. The disc e-brake kit from Man a Fre has a new flange drilled with both patterns in it . That leaves the front output ?
