FJ80 turns over, does not start
i only drive my 1995 TLC about 3-6K miles a year, but it started having problems starting, but only when warm (never on a coid start). so i took it to a small town auto place. i had hooked a small hand held tester to it and it claimed i had a faulty crankshaft position sensor. i replaced that with no change. so the shop replaced some other sensor (a module?), checked the ignition, replaced the entire distributor, and finally came to the conclusion that it need a new computer. at the same time of my ordering a computer, they called the dealer and learned that if my battery wasn't strong enough, the truck would not start. they also said that it had gotten to where it wouldn't start when cold. so they installed a battery and i guess it's fixed. so, did the "weak" battery ruin my original computer? or can i swap the old one back in and assume the new battery fixed it? i was lucky that they could return all the parts they had tried, and i can return the computer i purchased if that wasn't the fix. has anyone heard of this problem? oh, they also replaced the wires going to the 02 sensor because it had come undone from the frame "tie" and rubbed against the driveshaft (a problem i found after a search on this site, but i had only fixed it the best i could with tape).
