Fj80 Transmission Problem
I have a 1991 FJ80 with 140k and I am having problems with my tranny. When i take off at a traffic light it shifts smooth through all gears but right before it shifts from 2nd to 3rd if i let the gas pedal go, it kicks real bad. Fluid is good. Any ideas?
Fluid is good how? Condition of fluid, or level of fluid as checked per the owner's manual instructions?
If the answer is "both", then the next step is to adjust the "kickdown" cable that runs from the tranny to the throttle body. Search on it and you'll find plenty of results; it's a pretty common, usually easily resolved issue.
Welcome,
Curtis
Thanks Cjf!
I had been sitting in front of my computer and refreshing the page for a Reply. I am searching on that right now. Thanks again...
No problem. Stick around; it's a great place.
Oh, and actually the more common issue is a slight rpm "flare" between 2nd and 3rd when accelerating. I guess I'm thinking your issue is the same/related.
Curtis
(91FJ80, 243K)
