FJ80 Timing
Orange County California
Does anybody know how to set the timing on a 1991 FJ80? There was an old thread about it that also had pictures but I cannot find it anymore.:mad:
The instructions are in the attached file.:)
It's almost impossible to see the timing marks inside the bell housing so if anyone has a trick for that please chime in.
One trick I've used is: first, advance the flexplate until you can see the mark. Try pulling the coil wire and bumping the starter until it appears, a remote starter works well here. With the mark visible, use a white crayon, tire marker, chalk, soap stone, etc, to fill in the mark on the flexplate. Follow the FSM procedures and your timing light should now illuminate the white mark you placed on the flexplate. HTH
Thanks for the diagrahm. I new at this so I do not know what a Flexplate is. I know what the bell housing is so does that mean I need to get under the vehicle?
Also, What is a FSM???
I remember reading a post about downloading some sort of repair maual from a Toyota tech site. Does anybody know what I am talking about?
Also thanks, I will look up the FSM on the web.
look for threads on advancing your timing, I have a 91 and I set my timing at about 10 degrees, got a noticable power increase and fuel mileage.
I don't think it is available online anymore. I purchased an FSM on eBay for $80 and it has been worth the price.
Also, the marks on the "flex plate". This is the fly wheel. You can see this from the top on the starboard side of the engine (passenger side US) It's basically just behind (toward the firewall) from the transmission dip stick. There will be a rubber cover over the whole so if the engine compartment is dirty, it could be hard to find. Look at the picture on the FSM page I posted.
I assume you put it on 10° BTDC while the jumper is in place? What was the final timing (without the jumper?)
Also, did you get any ping with regular unleaded?
aha I am looking for that thread. Mines a California 94 so the 4.5 liter, you set the initial timing with the car all warmed up to 3 degrees jumping te1 and e1 (just like my 22re 1st gen 4runner) in the diagnostic box at between 600 and 700 rpm. 96 up you use an obd2 tool. mine was like 2 degrees retarded just above zero. Even 2 degrees out made a significant difference......though it could have been the air filter that I changed at the same time.
I will be investigating advancing the timing further, desiring better mpg more than power. What were your mpg gains on your 91 at 10 degrees?
From what I recall advancing the initial significantly runs certain risks what they are exactly I am not sure, predetonation and potential valve damage ring a bell. Had an old pontiac 66 with a 326's distributor professionally recurved at an old dynotune speed shop (had been points before, not HEI, never liked gapping points ) huge power difference. If i ever get a vehicle with coil packs i feel sure I wont miss adjusting my timing,,,well maybe.
Fsm is available from Toyota TIS site at 15 bucks for 2 days of access. It's not a simple task in making a copy for yourself. I just got done doing so for my 91. Have the service manual and full wiring diagrams in a nice PDF file. I'm still working to put the full book in proper order as Toyota doesn't present it to you in order but alphabetical topics. Ton of time but I didn't have the extra to spend on the alternative. Message me if you are interested and I can help.
