FJ80 Tail light problem
Austin, TX
I have a 1997 FJ80, and I have a tail light problem. The passenger side tail light works fine when the running lights are on OR when braking. If the running lights are on and the brakes are depressed then the passenger side tail light does not illuminate. The driver side works fine. The brake light above the tail gate works fine. The reverse lights work fine.
I have replaced the bulb. The bulb seems to be fine. I have disconnected the socket wiring harness and cleaned the connections because it was a little corroded. I soaked the socket in vinegar and then used emery paper to clean it up. I used compressed air to dry it. Then I added dielectric lube. After reconnecting everything the same issue continues to persist.
Anyone have any suggestions?
^^^ That is a good place to start.
Then read through the thread linked below. Your answer is most likely in there.
brake and tail light fail
