FJ80 Steering box
BC Canada
I just put an FJ80 steering box on my samurai. The steering knuckles run out of steering, lock to lock, before the steering box runs out of revolutions.......a good thing.
Does the steering box HAVE to be in the middle of the number of rotations, when the wheels are straight ahead, or does it matter? [As long as the box has enough rotation left, before the steering knuckles are hard-over on that side ].
My suspension geometry dictates that it needs to be [ centered with wheels straight ahead ] at 2 turns one way and 2.5 turns to the other side. I still run out of knuckle movement before I run out of box rotation as mentioned, even centered like this.
Thanks.
The box has a spring that adds tension to the sector shaft gear mesh when it is at center, to reduce free play at the steering wheel when not turning. Optimally you want the sector shaft centered when the steering is centered. I would imagine you could move the pitman arm on the sector shaft splines to whatever position you need it to be at, if that's the issue you are running into. Not sure if that would change the geometry enough to mess with the steering ratio left vs. right, but I doubt it, especially if the pitman arm is close to its original alignment.
Ok thanks. So having the box centered is better..........
I just built a panhard bar, drag link and installed OTT steering. Of course, I mocked everything up for fitment and clearance, correct lengths etc before welding it all up. Just after I finished welding the drag link to length, I tried it for fit. I found out I had the sector shaft adjustment screw too tight on the box and wasn't getting full rotation. Grrrr! That changed where the pitman arm is in relation to the DL and of course the overall length of the drag link. Now the DL and the panhard bar lengths are 7/16ths off. I had made them to be exactly the same length so to get zero bump steer.
As you had mentioned, I may be able to move the pitman on the box splines to correct this, otherwise, it will be choosing between unequal DL / panhard bar lengths, or steering box not being centered.
