So I have followed Gnob's thread detailing rebuilding the power steering pump. (url below)
forum.ih8mud.com
I have the disassembly done to entry #5 where he details the following:
"after the rotor/vane assembly comes out you have to remove shaft. start by removing the snap ring on the front of the pump. (I did this no problem)
next tap out the shaft from the backside with a brass drift. (done, again no problem, the shaft is out)
once the shaft is out, you can remove the front plate. i had to use a small slide hammer set that i use for doing pilot bearings."
Ok, the last one is where I have problems. I don't have a small slide hammer and even if I did I don't see where it would be used. How was the front plate (with the rods sticking out of it, see the second picture below) removed without removing the seal at the same time? How do you remove the front plate? Can you just put a socket on the seal side and tap/hammer the whole front plate and seal out in the direction of the front plate at the same time together?
Looking at the assembly drawing that came with the Toyota rebuild kit I think you should be able to press or hammer out the seal and plate from the seal side to the front plate side. There isn't any snap rings that would prevent this that I can see. I tried both tapping the seal out toward the plate using a socket and brass hammer, and I tried using a press to push it out in the same direction but I didn't get any movement so I stopped before I used more force because I thought I better check with you guys first to make sure I am not going to destroy something because I was doing it wrong.
So this is the seal side, I put a socket on the seal and both hit it with the brass hammer to get it moving but that didn't seem to work so I used a press to push on it from this side. that didn't seem to work either with the force I was using.
This is the front plate side. This is the side in which I was trying to push the seal toward, so the front plate would fall out toward in this direction.
So i guess my question is my methodology correct? Should I try again just using as much force as necessary to get it out, even if that means using a LOT of force?
fj80 and lx450 ps pump rebuild
decided to do a little write up for the 1FZ-FE PS pump since i didnt see one in FAQ. this follows the FSM but i try to add better detail and explanations. this particular pump came from a '96 LX450 first thing is to remove the pump from the car...
forum.ih8mud.com
