FJ80 pre-fabbed 3-link option????
It is a nice colletion of parts, but honestly, it would require as much modification/ fabrication as starting from scratch..
Mace, you're right...the same amount of fab, but it's the neat little package that makes it all better. Plus it raises the axle side panhard, which would help with alignment (FJ60 pitman arm to keep the same angles?). I like T-G, maybe if I was older and knew about the whole 'stealing design' thing, I wouldn't. But they have a good price, and helped me out on my sliders that I am putting on tonight, VERY beefy...
I'll check the Poly version, but I recall it having less included than the T-G. kit.
Yeah the Poly kit does not account for the offset axle, but could be made to work and the Poly guys are good folks
I am betting without a lot of lift, that axle end panhard will be a problem (frame interferrence)
doubt it would be under compression...
you'd be better off to do it yourself (as long as you can weld really well and you can figure out alot of odd things you will encounter) If you need a kit you may be better off to have someone else do it...not trying to be an ass, just realistically, you are going to put it back on the road and drive it at speed, you better be pretty confident in your skillz
I need a kit because I dont have the time or the right tools to make everything as well as the kit is made. I can weld, and cut a few things, but dont have the right tools to make any bends or notches. Plus, with college, I wont have but about a weekend to get it done, maybe 2.
Again, the modifications you would have to make to that kit are extensive enough that starting from scratch would be less time consuming...
Is that a general yota axle thing, or is this 80 specific? Action jackson didnt seem to have trouble with it, neither did sarmon(forgot his name). Couldn't you just mount the lowers right above the tie-rod and not have any issues.
I'd just say that doing it isn't ever going to be a "kit". Without the proper access to fabrication tools and skills it just shouldn't be attempted - you'll just frustrate yourself and end up with something a whole lot different than what you envisioned. It is also not necessarily a "cheap" process either, even if you think all of the labor will be DIY. The joints, dom tube, plate and brackets will add up even if you have the above mentioned tools and skills.
IMO, if you are dead set on having a 3-link, find a shop or fabricator that you can work with and afford and let them do it (maybe with your help).
You can leave the tierod in it's stock location but it will be the lowest point on the back side of the front axle.
The draglink and front panhard will work but with bumpsteer unless you go with a highsteer setup like Christo has on the Blueberry. BTW, he is uncertain if it will fit/work on the front of an 80 without interference so be prepared to deal with that. At that point you'll want to consider hydro-assist or full-hydro so there is another expense to consider.
Ok, could one keep the steering factory, deal with the tie-rod being vulnerable, and still use that kit (chop off the panhard mount from the kit and just use the links and link mounts)? Getting clean angles, notches, and bends are what I dont have the tools for, and it seems like that is just enough that I shouldn't even attempt this 3-link. I wonder if I have the skills to do an X-link???
