fj80 Please help
Wash off the engine drove home and park my LC and now I can not start the engine after two days. The engine will not turn over what should I check, thanks for any help
Pull off dist. cap and dry out with a blow dryer,remove battery cables from battery and clean contacts,check main efi under the hood. MIke
you got water into some of the electricals. don't know where.
Try the first suggestion, drying the dist cap. If that doesn't work, if you have compressed air, blow out the spark plug holes, and any and all electrical connectors you can see. if you can reach them, open them up (disconnect them from their component) and blow out both ends, then re-connect.
warm air is your friend here, this is not the best time of year to wash off your engine. :D
The exact thing happened to me. I had just replaced the alternator too. Got it towed and found out that something fried the alternator (that something was the idiot spraying water all over the place). Luckily I was able to get it swapped but it was definitely due to the washing. I wasnt as careful as I couldve been. One minute it was running good, I washed it and immediately it began giving me problems then died. Check the alt.
If it won't turn over at all, then check your battery. If it turns over but won't fire, check your efi relay and you ignition components.
