Fj80 inconsistent braking
Denver, CO
hey guys, me again. So I know I'll catch flak for this, but had someone offer to replace my brakes at no cost to me (Big oh no! tires). Anyway, they changed out pads/shoes and new rotors up front along with a new master cylinder and brake lines. Now I have "inconsistent braking" at times the pedal feels rock hard and I can actually feel the truck dragging, like a pad is stuck. Other times it's totally fine with way more pedal travel. I've been back to that shop 5 times now trying to fix it, and now they're saying maybe a bad (new) master cylinder. Wanted to ask to collective genius of the mud mind on thoughts before taking it back. I'd almost prefer to dig into this on my own at this point, considering they don't seem to know what the eff to do. Any ideas? Thanks in advance, guys... This forum is invaluable to a LC newb like me.
Assuming they did not use OEM parts? I went the "budget" approach a while back on my first 80 and had all types of brake issues. Ripped it all out and installed all OEM stuff. All issues went away. Not sure if this is your issue, but I figured my experience might help.
I appreciate the feedback. I'm sure they didn't use OEM parts and now I'm kicking myself for letting them touch the cruiser in the first place. All i know for sure if the master cylinder says "Aisin" on it. I'm tempted to just stick it to them and make them fix it considering the money that was spent for everything (although not out of my pocket). I just want to get it right.
"Aisin" is good. That's the OE manufacturer. It's the those budget AutoZone and PepBoys master cylinders that will kill you. The one I originally installed was a "premium" one from AutoZone. After cross referencing part numbers I found out it was the rebadged economy grade Centric brand. Total POS. Ordered an "Aisin" one from ebay and never had issues again.
... Now I have "inconsistent braking" at times the less feels rock hard and I can actually feel the truck dragging, like a pad is stuck. ...
Sounds like they failed to adjust the push rod in the booster, needed to be shortened, but could be a bad master. To test, pump the brakes several times, is it dragging, if so, briefly crack each bleeder, this should release the brakes.
The brakes do seem to stiffen and drag the more that i pump them. Also, i noticed more of the stiffness and "sticking" after the car sits in the sun ang gets hot for a while. Otherwise, it's hard to say what else is happening. There are literally times when i need to tap up with the top of my foot on the brake pedal and i can feel them "unstick". It's almost like even a small amount of heat on the pads causes the brakes to start engaging. Hope that makes sense.
Maybe your pedal is not move back up freely. Maybe the return spring is broken.
I wondered that as well... but the problem literally started the moment i drove it away with a new brake setup. Hard to imagine the coincidence on the timing in my book. I'll take a look at that today thought to rule it out.
They claimed it was an issue with the rear proportioning valve needing adjustment after I lifted the truck. Drove away... Same issue. The braking system is building too much pressure at random times still. Could this be a brake booster issue?
I sure would revert back to your original system if possible. Many LC owners deal with constant brake issues for years, so if you ever had a point in its history when things were dialed in, I'd go back to that in a heart beat.
You said new brake lines too. That's another issue that if just one line was not flared correctly, air and fluid loss will kill things quick. If they sourced the rotors from a non-spec Chinese manufacture, there's no telling where a point of fault could be.
I'd stick with Toyota oem or oe parts and start over at a Toyota licensed shop.
It will hit your wallet I know, but it's a heck of a lot cheaper than being in a bad situation when you needed your brakes to perform in an instant.
Taking it back in for one last go this time... i mean after the money spent i want them to fix it correctly (maybe too stubborn of me). Same issue persisting... drives around normally/fine, then I'll be rolling along or pulling away from a stop and the brakes are sticking. Using the top of my foot, i can tap up or push up on the brake pedal and it'll resolve itself. No changes to the pedal spring during overhaul, and essentially the only thing not replaced is the brake booster. Brakes work great otherwise... just a random sticking issue that won't go away. IF this next round doesn't resolve it, i wonder if i even have any recourse to recoup any of the labor costs from the shop?
