FJ80 frame differences between 92 and 95+?
I understand that the Fj/FZJ frames have the motor mounts for both the gasser and diesel drivetrains, but the HDJ81 frames don't have the mounts for the gasser.
Not sure if this:
a) is true
b) helps you
Pretty close
91-92 FJ80 frame has mounts for a 3FE, and not for anything else.
9208 up FZJ80 frame has mounts for 1FZ-FE and an extra slot on the right which will accommodate 1HD-T
90/01 -92/08 HDJ80 have mounts for 1HD-T only.
Not sure about 92/08 up HDJ81, more than likely same mounts as the FZJ
I heard somewhere that the shock mounts on the FJ80's is slightly different than the FZJ-80's. Thats why the FJ80's seem to sit higher than the FZJ's. Thats just hearsay of course...
