FJ80 Factory Wheelset
Los Angeles (Palos Verdes Peninsula), CA
Hey guys, I have a '95 LC with stock 16" wheels. Does anyone know if the '91-92 15" wheels will work with the newer ABS brakes etc.? I much prefer the look of the older vintage wheels and know someone who has a set. Thanks in advance.
Also while we're at it, what's the largest BFG KO2 that will fit on the older 15" and the newer 16"? I know for the 100 series a 285 was the max, not sure about the FJ80.
SNIP
On the stock suspension, you can run up to and including 33" diameter tires. I run the skinnies in my tag line, but wider will also work (within reason and provided your rim width is otherwise suitable). If using the stock spare location, up to 33" tires will fit, but the wider the tires, the more of it will be exposed under the rear crossmember. There is a simple mod that will raise the spare tire winch up a little, thouigh.
Thanks!
