Greetings to all: On several occasions the claxun is constantly ringing when I turn on the truck I had to disconnect it to avoid the noise. What you suggest may be. Check the button in the guide but it seems okay. Help thanks.
Thank you. This situation does it in some moments only. And that's when I start the engine. The truck has an alarm but the siren is separate. It is not connected to the horn. For now, what I have done is to remove the cable that reaches each horn (have 2) disconnecting the plug of each of the horn.
It sounds like there is a short somewhere in the horn circuit.
With the truck off (key out), will the horn button in the middle of the steering wheel activate the horn as it normally should?
Does the problem occur when the steering wheel is turned to a certain position?
If the problem only occurs intermittently, and only when starting the truck, my first area to inspect would be the area in and around the ignition switch. Remove the plastic clam-shell cover around the steering column and look for pinched or worn wires that could be causing a short.
That is my layman approach. If a problem occurs between two separate systems, start by looking where those two systems intersect.
There are many minds on here that are far more familiar with the 80 electrical system than I am so hopefully you will get some more suggestions.
