I need some help problem solving my oil pressure gauge. let me say first, that I do not want to put a mechanical gauge in the system. My 62 is all original and everything works perfectly except the oil pressure gauge and I don't want to add an auxiliary gauge to the system. The original system worked and should be made to work again.
I've replaced the sending unit and have tested the gauge by placing a 12v bulb (resistance) between ground and the gauge lead (black and yellow wire). The gauge needle starts climbing although ever so slowly.
The problem is I can not find any detailed info to problem solve. Does any one know what the voltage should be coming from the gauge lead? Mine measures system voltage (~13+ volts). I would think the voltage would be less since it passes through the gauge. If I new what the voltages and resistance of the gauge and sending unit should be I can determine where the problem lies. Though I believe the problem is the gauge I would like to verify it. The fact that I can make the gauge needle move by putting resistance in the circuit makes me hesitate to replace the gauge.
After replacing the sending unit, I measured the resistance while the engine was running and the resistance is roughly 45 ohms. Seems right but again, I don't know if this is correct either. I tested the oil pressure and I have good oil pressure.
Help Please.
Help Please.
