FJ62 Oil Cooler Assembly Cleaning Tips?
Republic of Texas
On this assembly, can I remove the nuts and stick it in some decreas
er? Don’t wanna cause more problems with the internal passageways
Thank you.
That's the oil filter adapter, not the oil cooler. I would not submerge it in degreaser. Those passages inside need to be clean, and you definitely don't want solvent in them.
Thank you Lead Head!
I chicken'd out. Taped up all the openings and went at the outside with a brass brush. Later when I removed the large bolt near the oil filter, there was a spring inside and some sludge! I wonder if I need to check that spring each time I do an oil change?
Lead,
Is there a ball bearing or anything under the spring? I only found the cap and then the spring.
Ty!
Found it! There’s an oil relief valve stuck in the housing. Will clean that out. When in doubt refer to the manual!
Ty!
