WoodnotRust
- Thread starter
- #21
Bump....still missing photo of 1990 California Emissions sticker (need dimensions in mm). 1988 and 1989 sticker sheets are now available for $45 (7 available).
Thank you @88red . I didn't expect a BAR CODE, so that will be a bit of a challenge. I'm still unsure of the dimensions, but I can mock-it up with this photo and go to print after I can confirm the size.Only photo I have of a 1990 California
Well...how cool is that!! I'm just using PowerPoint to tediously recreate each of the stickers and it will be easy to insert this bar code image. That said, I had purposely used an off-white background color to "age" the sticker somewhat, so the bright white of the barcode might contrast. I might be able to make the white transparent to solve this problem...regardless, I've learned yet another helpful bit of info from a MUD member. ThanksI used a bar code app on my phone to read the barcode from the picture in the post above. I put that result into a free barcode generator selecting the "code 39" type barcode. You can get the barcode as a JPG, EPS or SVG file. Not sure what program you are using for the label, but it's pretty easy to stretch a JPG
No apologies necessary...this is a nerd safe space. Here is my version using your bar code image with the white set to transparent in .ppt. I considered re-doing the bar-code line work since the fine lines in the original are finer relative to the fat lines...but, that's one of just many differences. I'm going to call it 'good enough".sorry for being a nerd.
I no longer have the sticker but from what I recall it was the same size as the 88. I’d be in for a full set 90cali emissions. I need two other sets but need to confirm yearsNo apologies necessary...this is a nerd safe space. Here is my version using your bar code image with the white set to transparent in .ppt. I considered re-doing the bar-code line work since the fine lines in the original are finer relative to the fat lines...but, that's one of just many differences. I'm going to call it 'good enough".
Now, if I can only confirm the exact dimensions and find members willing to buy a full set of 1990 FJ62 stickers, it can go to print.
Thanks for your help.
Hi Matt...nice decals. The aluminum foil versions are the real deal and what the purist wants.
@WoodnotRust yea my FJ62 was originally bought in CA and I brought her back out here about 8 years ago. So looking for the combo sticker. The photo in my profile is my HJ61 which I got about a year ago. She’s a work in progress, but looks the part! HahaThat's a nice looking rig @umman manda. Was your FJ62 originally sold in California? FYI, my sticker sheet comes with both the Fed and California Emissions stickers, but I have an earlier Federal Emissions sticker version for the 1988 that I'll send to you for $5 if that is all you need.
Anyone interested in sprucing up the engine bay in your FJ62?Bump....still missing photo of 1990 California Emissions sticker (need dimensions in mm). 1988 and 1989 sticker sheets are now available for $45 (7 available).
