FJ62 EGR Temp Sensor Connector
GRM
Finding new adventures in old jalopies.
Moderator
Livermore, CA
Hoping for some help with my 2fe:
This green with white stripe and brown with black stripe 2-wire connector inside my intake manifold fell down and melted on the header. In looking at the harness drawing, I believe these wires go to the EGR temperature sensor.
My ECU is a 89661-60020, which is a federal 1988 FJ62 model.
I need to fix this wire.
When I let it flop around, it would ground out and cause the engine to stall at stop lights.
Do the wires stay separate and disconnected? Or do I connect the two together? I’ve seen in some photos of federal FJ62’s these wires are connected together; but I’m not sure if that applies to my setup or not.
For the last year, they were zip tied out of the way and I realized the wires were touching.
I appreciate the help.
I found this fj62 diagram, showing the green and brown wire tied together on federal ecu’s.
Since I have no idea if this is a 1988 diagram or not, I decided to install a dtm connector with a jumper so I can run it either way.
