FJ62 4wheel drive vacuum?
ok i was in a rush before... let me explain. It was in 2 wheel drive and i always left it that way because the P/O warned me of this. Apparently there is a vacuum set up on 62's thats why there is only 2H and 4L on the transfer manual shift. I was on some ice on the side of a mountain and had to put her in 4L. I figured it would manually engage and then release later when i put her in 2H as long as i didnt push the button. unfortunatly it didnt work that way... how do i disengage it? i kno it has something to do with the vacuum, scematics anyone. this is kinda a big deal seein how she's my daily driver
it could be a buggerd solinoid i've got the same set up on my rig there should be two solinoids mine are located on the front wheel fender pannel and then have a vacuum lines(2) running to the front axle and the vacuum is supplied by the alternator. preatty much any vacuum activated solinoid will work but i used ford cheap & at 10-15 bucks a piece you caint really go wrong mine have been working great 5 years now no problems no complaints.
