FJ60 Flat pitman arm...
Silicon Valley
This is a CNC flat pitman arm for FJ60 steering box. If you're running FJ60 powersteering conversion and spring-over axle with 4x4 Labs high steer...This is the one for you!!! It's already tapered for 1-ton tie-rod end. It was installed once but never used because I decided to go with Saginaw instead. Perfect condition.
/td
