Fj60 Fj62 Chrome Rocker Molding
Is there a proper technique to remove the snake blinders preventing damage? I'm, very slowly, stripping down for paint. I have one good trim left on the 60, and I just noticed I purchased a new one from CruiserParts in 2013 for $129! I should have bought a pair!
So worth a mention that in addition to the 5 clips/retainers on each side there are also 2 screws with grommets securing the front of the snake blinders:
9353064020​
4
$ 0.79​
SCREW, TAPPING
9018904001​
4
$ 1.89​
GROMMET, SCREW
Once you remove these things should loosen up if they are not already. You can use a plastic trim/panel removal tool to get behind the trim and pop out each clip. Honestly if like mine just gently pulling with your hands will be enough.
9353064020​
4
$ 0.79​
SCREW, TAPPING
9018904001​
4
$ 1.89​
GROMMET, SCREW
Thanks for the info! I was thinking spatula😕. I should probably count on replacing the clips?
Inr
I replaced all my hardware. On driver side it was hanging on by one clip and the screws. Also before I reassembled I sprayed inside the rocker holes with Fluid Film.
I found the trim clips needed for the rocker panels (snake blinders) and you'll need 5 per side (as mentioned above):
I also found them on ebay, but they were listed @ $10/ea.
