FJ60 engine stuff
hyrum Utah.
Did an 350 conversion on my FJ60, so now I have a longblock and heads ready to go. The little lee plug blew out of the side of the head, evacuating all of the oil, then I put a new head on, then it was the wrong head with now oil path to the top of the engine, so now before I throw any more effort at it I ripped it out and am swapping in a 350.
Engine turns, early 2f head is freshly machined. Includes water pump, starter, fan and a AC compressor that leaks.
Located in Hyrum Utah (Northern Utah)
50 bucks
Carburetor available separately for 50 bucks. The carb has always worked flawlessly! I got 16 mpg out of my ride with the carb.
I can ship the carb, but not the motor.
801 814 1034 from noon to 5pm
Thanks, Marc
Can I get a little clairity? The head you have for sale is or is not the correct one for a FJ60? I am looking for a head that will work on a 85 FJ60.
Thanks
Chris
87 FJ60
85 FJ60
75VJ40
The head that is on there now is the incorrect head. The original head had blown a lee plug out the side causing all the oil to pump out. I ordered a new head and during installation I noticed that it did not have an oil path to the top of the engine. If I would have run it, I would have burned it up. SO it sat in my garage for the winter. Now I've ripped out the I6 and am installing the 350, and I will not be needing this anymore.
The head is the early style with NO lee plug above piston number 5.
