FJ60 Conversion Confusion
Tennessee
Do I need the manual torque converter lock-up switch (Painless Wiring) with a ' 87 - ' 92 700R4 2 WD donor transmission? If I understand, the 700R4, before 1993 is hydraulic rather than electronic anyway. I plan to transfer everything from the donor vehicle; ecm, sensors, etc to the FJ, so, in theory, the donor components should be undisturbed? Final drive ratios are comparable in donor vehicle and FJ60, about 3.70:1 for Chevy Van, Truck, Suburban or FJ60?
I have tried to read every post about wheel fitment before asking my question, please forgive me if the answer is already listed somewhere, but here goes;
Does anyone know if the M/T Classic II 16X8, 6-5.5" with 3.625 BS wheel will fit a 1987 FJ60 and clear the TRE'S and calipers?
I am almost finished with painting; AlanH-Pics - Photobucket - Video and Image Hosting
then plan OME Dakar Suspension lift and M/T Classic II 16X8 Wheels with 285-75-16 AT Revo's (33 X 11.50) tires.
This is a great site. I am gaining a tremendous amount of knowledge.
Thanks for all the help,
LC4EVER
1987 FJ60 Frame Up Paint, so far !
If you use all the sensors, wiring with ecm from the donor sub., the lock up will be controlled by the ecm as orginally in the sub. The trans. has 12V going to it all the time except when the brake is pushed. the ecm creates a ground for the lock up when speed, tps, & map. reading are correct for lock up.
Jimmy
Also this veh. has a speedometer cable with a vss in the speedometer which sends inf. to a buffer that sends the speed to the ecm so it can control lock up and idle speed when you stop you will have to add one in the cable and use the buffer too for proper operation.
I researched my conversion using the official GM repair manual for the model of vehicle that I got the engine and transmission from. For my tbi, the car used a buffer, but it was only for the info provided to the cruise control unit and not the ecm. The ecm took a straight feed from the speedo output on the transmission. I got an inline pulse creator that made the correct pulse per mile output for a TBI and ran the wires directly to the ecm using the Howell harness.
I wired up my o/d TC lockup using the correct GM brake switches that had both a normally closed AND a normally open circuit so that one circuit operates the brake lights (n.o.) and the other operates the lock-up (n.c.). Power goes directly to the TC UNTIL the brakes are applied and power goes to the brake lights AFTER the brakes are applied.
If the TC lockup occurs too early for your liking, the ecm can be modified to raise the speed at which the ecm allows lockup. I haven't done this, yet, but I plan to. I don't have everything that I need to burn a chip, yet. As is, with the 410 gears in my fj62, the TC will lock-up after shifting into fourth at around 37 mph if cruising on an easy flat strecth of road. It unlocks pretty easily with a little extra gas, so it doesn't lug the engine at all.
The nice thing about setting it up this way is that I can actually use the installed brake switches and a buffer that I kept to hook up GM style cruise control since the stock parts already had the extra plugs and vacuum ports for the stock cruise control servo. I'll get to that sometime...
ecm wiring
Turtle60 is correct some computers do have vss straight to them and then to the buffer, but I was speaking about the 1227747 computer which is found in most 87-90 trucks & sub., the buffer in these sends inf. on one wire to A-10 connection on the ecm. If you need a wiring diag. I could send it to your e-mail add.
Thanks, Jim I will definitely need help with the wiring when I get to it. I'm almost finished with paint, then cut & buff the clear. I'm shopping a donor vehicle now. I see some that look bad, but maybe have a new rebuilt transmission with receipts, etc. My FJ60 has 110K miles, but it sat in the PO'S yard for 10 years, so I don't know what that might have done to the knuckles, hubs, transfer case, etc.
I like the simplicity of a '87-'92 5.7 TBI W/700R4 conversion. Some people don't like the L05, but it was designed for torque and mileage and 210HP and around 300ft lbs should move the FJ60 fine. I understand with the Downey or AA adapters I will need a 2WD Transmission or change out the output shaft with one they will provide.
Is it a big deal to change the output shaft on a 799R4?
My FJ60 had a carburetor fire that toasted some of the wiring on the driver's side. The hood release cable and blinker wiring was sort of conglomerated together with a few hoses and vacuum lines. I first planned to restore the 3F, but emission tubing was missing and the diagram showed waaaay too many to replace. I started pricing the replacement items at Specter and it became an easy choice to go with a TBI conversion. I could have replaced all that stuff and still failed CA smog !
I appreciate all the help. I like the 700R4 30% overdrive and the A/T will make it more friendly for my wife to drive. I would love to make the GM cruise work. I was thinking about switch location, etc.
Does anyone know if the M/T Classic II 16X8 wheels will fit?
I used a 2wd version of the 700r4 and just cut off the extra shaft - no need to change the output shaft. I'm pretty sure that that is one of the options with the AA kit. It was fully splined and the shaft went full depth into the spud shaft.
I got a lot out of the jags that run book and website.
That shaft BTW is hardened steel (at least on my 4L60e it was), and had to take it into the tranny shop to get it cut. Blew two cutting disks before I said a few words and surrendered. Fortunately they didnt even charge me...showed them pic's of what it was going in, and they "donated" the work for me. Hope they arent expecting me to come in anytime soon...
I was able to cut mine real easy with a cutoff wheel on my dewalt grinder. Took it slow and used one wheel. Used a piece of tape to mark the cut line so that I wouldn't go crooked and dressed the splines lightly with a file.
The donor truck cruise will work, just hook it up same as the truck. It should hook up to the 2000 pulse connection on the buffer for input of speed to the cruise control, I like the 91-93 cruise units from the gm trucks very simple to hook up only one box and a cable to mount.
