- Location
- United States
ok how much for the tits? looks like the mount tabs are broken , got anything better?Hello Mr. skhochay
I have your unicorn :
View attachment 2990486View attachment 2990487View attachment 2990488
$Not 100% sure this thing works as it has never been connected to anything since I have owned my FJ60, but I did ohm it out while heating it up with a propane torch and it dropped in ohms as it got hot and when it got red hot seemed to hang around 30-50k ohm and then go back up to a few mega-ohm at room temp.
it is useless in many cases as this i not O2 sensor as many think , this is heat probe for CAT . only one purpose for this measure CAT temperature, why so in case you are driving over a tall dry grass in safari so your car did not ignite the fire and burned the entire AfricaNot 100% sure this thing works as it has never been connected to anything since I have owned my FJ60, but I did ohm it out while heating it up with a propane torch and it dropped in ohms as it got hot and when it got red hot seemed to hang around 30-50k ohm and then go back up to a few mega-ohm at room temp.
ok your PayPalHow about $60 shipped USPS Flat Rate? Send me a PM if this sounds good and then I will send you my PayPal info.
