Fj60 1987
Plano texas
Parked cruiser today,grabbed the Ram. Got in the 60 smelled burning and had buzzing behind dash-steering wheel area. Both turn signals were on at the same time But not flashing. Any thoughts working 7 days a week. Thanks, Mike
First disconnect the battery just incase the fusible link or a fuse did not blow. Check your fuses and see if one blew, if it did that is the circuit to start looking at. With no details I would suspect the hazard circuit is a starting point. It is a key off hot circuit and connected to the turn signals. Maybe just the flasher shorted and no wiring was damaged.
Take off the gauge cluster and look for the melted wire. Check that you dont have the wrong fuses installed. The fuses should pop before anything burns. Check to see that no aftermarket wire is running through without a fuse.
I’ve had the truck since almost new,only an aftermarket Alpine radio in it which I bought new 30 years ago.
Buzzing and still no start. Never seen this before. Removed radio which needed replacing but was not the solution. Mike
Embarrassing but always check simple stuff first. I didn’t look at the battery or alternator since they were one year old. Auto Zone Gold had a short in it. Hopefully I’ve learned my lesson,check simple stuff FIRST !
